Order Ford 3000 Parts Online
3000 Oil Wash Air Filter?
G.W.
12-03-2001 18:31:48
What is the correct procedure on the assembly of
the air filter in regards to the bottom pan and
the inner bowl? Which one contains the oil and
how much and what weight? Thanks.
JDP
12-04-2001 14:50:11
 Re: 3000 Oil Wash Air Filter? in reply to G.W., 12-03-2001 18:31:48
I agree with Greg. We do the same thing on our 5000's. Just don't overfill!!
Greg NE
12-03-2001 18:53:15
G.W. I'm not familier with the 3000, but on a 5000 and on an old style 4000 and a 8N they are all the same. We use the same oil as the motor and it is filled up to the line on the inner cup after you put it in the bowl and fill the cup and the bottom bowl at the same time. That is how my Dad has done it for a lifetime and the tractors have given good service. P.S. check your manual and it should have a section on servicing your tractor. Good luck Greg NE
