850 question
Air Force One
11-02-2007 07:01:47
My 850 Ford ran fine..till a few days ago..It starts well, but after running for 5-10 Minutes when using disc, after letting out clutch...it stops or when just crusing down a path it stops. It will only start using the choke?/ Any suggestions? Thanks
old
11-02-2007 08:53:51
 Re: 850 question in reply to Air Force One, 11-02-2007 07:01:47
Check for good fuel flow at the bottom of the carb and at the line going into the carb. You may have a clogged fuel line and or a stuck float
