Rear end or hydralic dipstick on 850?
Alan Peterson
11-04-2007 18:39:00
Hi, New to the forum here, and thanks for the help. I have a recently acquired '57 850 Ford, and in getting it ready for winter snowblowing I discover the three point won't lift my snowblower.
I have a dipstick on the left side, by the PTO lever, that indicates full. What reservor is this dipstick checking?
When I pull the three caps off, all reservors are wet with fluid, but I don't see the fluid in any of them, so I'm assuming all are low. How full should each resorvoir be?
Does anyone know the capacity of each, if I drain them all and start with fresh 134D in all? Are there any screens anyplace that need cleaning?
GlenIdaho
11-04-2007 19:23:17
 Re: Rear end or hydralic dipstick on 850? in reply to Alan Peterson, 11-04-2007 18:39:00
Alan; the Capacities are as follows; Engine - 5 quarts (when replacing filter) Transmission - 8.5 quarts Hydraulic system - 8 quarts Rear Axle Differential - 11 quarts
The only screen you will find is when you pull the drain plug on the engine. There is a cylindrical screen that sits in the plug.
Alan Peterson
11-07-2007 21:31:54
 Re: Rear end or hydralic dipstick on 850? in reply to GlenIdaho, 11-04-2007 19:23:17
Thanks again for all the help. I found the "burp" plug, and my hydralics now work fine.
Fluids all changed, I'm set for winter!
Alan Peterson
11-04-2007 20:25:48
Thanks, to all. I very much appreciate the wonders of the internet!
soundguy
11-04-2007 18:44:02
An owners manual would help with these wuestions.
The dipstick onthe left side is the hyd dipstick for your 3pt hitch.
The check level plug fo rhte diffy is on the left axle trumpet, rear of it.
Trans check plug is on right side by your foot...
soundguy
Alan Peterson
11-04-2007 18:50:39
 Re: Rear end or hydralic dipstick on 850? in reply to soundguy, 11-04-2007 18:44:02
Thanks, soundguy! I just found this site, and through it also finding manuals. As I mentioned, my dipstick indicates full, but the three point won't lift, even with nothing hooked up. It worked this summer when I acquired the tractor.
Any ideas as to why or what to look for?
Anyone have a recomendation to the best manual for this series tractor?
Billy NY
11-05-2007 09:10:07
 Re: Rear end or hydralic dipstick on 850? in reply to Alan Peterson, 11-04-2007 18:50:39
The factory shop manual and parts book I thought were the best for these tractors are offered by Faxon Auto Literature as a good quality reprint, also keep a look out on e-bay, originals turn up there as well, years ago I found an original for mine, and noticed the above offered the same in a re-print.
soundguy
11-04-2007 18:54:15
factor service manual is better than the fo-20.
I'd pull the front/top plug on the end of the hydro pump and see if it needs burped.
soundguy
