Ford alternator
Bob
11-04-2007 22:38:44
The Ford alternator in your photos needs an EXTERNAL voltage regulator.
For it to charge, you need voltage from the regulator TO the FLD terminal... the more voltage and the FLD terminal, the more it will charge.
To check to see if the alternator itself is working, simply remove the wire from the FLD terminal, and insulate it, and move it out of the way. Jumper full battery voltage to the FLD terminal (full-field it), start the engine, and the alternator should charge at MAX output.
Third Party Image
Above is a simple diagram, commonly used in ag and industrial stuff of that era, showing how to wire up the regulator and alternator.
Joe)NYC)`
11-05-2007 05:36:23
 Re: Ford alternator in reply to Bob, 11-04-2007 22:38:44
third party image
Bob,
There is a voltage regulator with the I, A, S, F leads but it is unplugged. Mine shows the 'I' lead on the plug going to one terminal (block of 2 leads) which goes to one side of the ignition switch and also to one side of a resistor at least 10 WATT(could read resistance but will measure it next time). The 'A' lead goes to the second terminal(of the above block) and from which 3 leads go out, one(black) to the second side of the ignition switch, two(blue) to one side of the ammeter, three(a heavy yellow) I bekieve to the solenoid. The 'S' lead has 2 wires going out but was not able to trace them. The 'F' lead has one wire(green or blue?)but could not trace it out either. My alternator also has 2 ground connections and the 'STA'(stator?) connection. Right now the stator has a BLK wire going someplace(?). On my next trip up I will try FULL FIELD hookup and see if it puts out juice. Thanks for the reply. Joe in NYC.
Bob
11-05-2007 05:58:07
 Re: Ford alternator in reply to Joe)NYC)`, 11-05-2007 05:36:23
Sounds like you have LOTS of unneeded wires there!
The diagram I posted is the simplest I've seenm and DOES work.
All the extra wires you have... a guy WITHOUT a diagram tried to transfer over a charging system from a car, complete with a bunch of unneeded wires.
IF you HAVE to have an "idiot light" (NOT shown in the diagram I posted), things get a little more complicated!
Joe)NYC)
11-05-2007 20:34:36
 Re: Ford alternator in reply to Bob, 11-05-2007 05:58:07
Bob,
The guy I bought it from used it mostly for tractor shows and it has all new gauges icluding AMMETER, TEMP, OIL PRESSURE, PROFFMETER. I know, it's supposed to have a idiot light not a ammeter. I really would like to continue having the ammeter since it's there and looks really nice. Right now I know that the leads at the ammeter are hooked up backwards. The higher the rpm's the more the meter reads on the 'plus' side. But the voltage at the battery reads less and less with higher rpm's.
Jon Hagen
11-05-2007 20:55:43
 Re: Ford alternator in reply to Joe)NYC), 11-05-2007 20:34:36
Bob's diagram is correct for that alternator with an ammeter system. Your picture also shows that you have the aftermarket solid state regulator,good part, much smoother voltage regulation than the original mechanical regulator.
Joe)NYC)
11-05-2007 21:17:37
 Re: Ford alternator in reply to Jon Hagen, 11-05-2007 20:55:43
John,
The solid state regulator as you can see is unplugged as I got it. I am afraid of plugging it in and and seeing smoke go up. I have to analyze the situation according to the suggestions I am getting. And, of course, being 240 miles away from the tractor doesn't help much.
Jon Hagen
11-05-2007 22:08:57
 Re: Ford alternator in reply to Joe)NYC), 11-05-2007 21:17:37
Good luck, you should rewire to Bob's wiring diagram. For an ammeter system, there should be nothing connected to the regulator I terminal, or the alternator STA terminal. They are only used with a charge light system.
Joe)NYC)
11-06-2007 19:10:59
 Re: Ford alternator in reply to Jon Hagen, 11-05-2007 22:08:57
John, thanks for the info. I will try this method. If the weather holds up I may get a chance to do it this year, otherwise not until next spring.
