Changing the tranny and Hydro fluid
Andy MN
12-04-2001 16:26:53
Just took the 850 home. The guy I bought it from had done most everything I had planned to do execpt swop out the Hydro / Tranny fluid.
I duetifly bought a FO-20 manual and got it today. When checking the "sizes - Capacities - clearences" section it said, "Hydrolic Resivoir - quarts 8 (quarts) refenence subsection #4.".
Subsection four states, "on models with both hydrolic system and PTO, leave hydrolic resivoir empty.".
What gives? Does the 850 share a trans / hydro system like the 9N, 2n, 8N tractors? This tractor has live hydro, why would you leave the hydro res. empty/
Very puzzled.
Andy
James
12-07-2001 11:26:50
 Re: Changing the tranny and Hydro fluid in reply to Andy MN, 12-04-2001 16:26:53
New Holland dealer told me to put 134D in all three fills also(Model 640). 134D is a 10/30WT oil. I bought the oil and did this. At the same time I ordered a reprint of the original owners manual, took about a month to get. It gave a speck for the hyd oil which the 134D probably meets but it clearly said to put medium pressure 80/90 WT gear oil in the trans and rear end. There is a big difference in these oils. Heavier gear oil makes sence to me for the trans and rear end. I am going to change to gear oil in my tractor before I use it next.
Good Luck
James
Phil (VA)
12-08-2001 11:28:27
 Re: Re: Changing the tranny and Hydro fluid in reply to James, 12-07-2001 11:26:50
One thing to keep in mind, if you have a rear seal that is prone to leak, axle or pto, the 134 will leak quicker than gear oil, for obvious reasons.
Tommy D.
12-05-2001 09:29:15
Just a suggestion -> Shelf the I&T manual and spring for the $60 for the manual from New Holland. MUCH, MUCH better, and TONS more details and pics.
Good Luck!
Tommy D.
Jim.UT
12-05-2001 13:05:48
 Re: Re: Changing the tranny and Hydro fluid in reply to Tommy D., 12-05-2001 09:29:15
I got a FoMoCo reprint shop manual off ebay for about $25 (including shipping). Does NH have one that's better now? I agree that the I&T manual (I have that one too) is inferior.
RickB.
12-04-2001 16:39:21
Your 850 has separate trans, hyd, and rear axle reserviors. Total capacity is around 6 gallons. I am not familiar with the quote from the manual, but do not leave any reservior empty. NH 134D hydraulic fluid (or its equivalent) is the current spec oil for all 3 fills.
