Order Ford 860 Parts Online
860 exhaust
Bob Thomas
11-06-2007 17:33:33
On my gas burner, I need a new exhaust system. How does one know if it is the "large" or "small" system? Or does it matter if I am buying the tail pipe and muffler? Thanks in advance.
GlenIdaho
11-06-2007 18:06:03
 Re: 860 exhaust in reply to Bob Thomas, 11-06-2007 17:33:33
Hello Bob; Measure the diameter of the elbow outlet located on top and to the rear of the manifold. It will be 1 5/8 in. dia. or 2 in. dia. Most likely on yours it's a 1 5/8 in. unless someone changed it. You'll need to match the elbow outlet size with your muffler and the muffler to the exhaust pipe.
There were two different sizes used by Ford; 1 5/8 in. and 2 in. The 1 5/8 in.elbow part number NAA 55250 B was used on the 134 CID from 53 up and on the 172 CID from 55 thru 1957. The 2 in. elbow, parts # 310075 was used on the 172 CID 58 up. Hope this helps.
Bob Thomas
11-06-2007 19:38:57
 Re: 860 exhaust in reply to GlenIdaho, 11-06-2007 18:06:03
Glen--Thank you. You are always most helpful.
