Wire resistance?
Bob Jarvis
11-06-2007 18:01:24
Just bought a new set of wires for my 3000 at the local New Holland dealer. For curiosity I ran a resistance check on 'em and found they're all registering about 3300 ohms resistance. I would've thought they were solid wire and should show about zero resistance. Can anyone help me understand this? Thanks.
Air Force One
11-08-2007 07:46:05
 Ford 850 Pointless Question in reply to Bob Jarvis, 11-06-2007 18:01:24
Has anyone switched to >Electronic Ignition Conversion Kit - 12V Negative Ground for a 800 Series Ford Tractor? I was thinking about going total Electronic, but wanted to get anyones opinion on this...thanks
soundguy
11-07-2007 05:19:17
 Re: Wire resistance? in reply to Bob Jarvis, 11-06-2007 18:01:24
Incedentally... you can't get metal core wires from CNH or so I've been told.. so.. if you order wires for your 8n.. they will come in carbon composite as well..
Soundguy
36 coupe
11-07-2007 02:44:56
These so called wires measure about 10000 ohms per foot.They do fail often.I find many measure open.I check them first when an engine skips.The plug on the bad wire will foul.
Bob
11-06-2007 18:44:01
Solid-core wires are only needed for 6-Volt or "mag" tractors. Your's will be FINE with the OEM-replacment wires.
MarkB_MI
11-06-2007 18:36:07
Factory wires will be carbon resistor type. The intention is to cut down on interference with radios. You can buy aftermarket copper wires, but don't expect any big difference in performance.
36 coupe
11-07-2007 13:19:45
 Re: Wire resistance? in reply to MarkB_MI, 11-06-2007 18:36:07
You will see a big difference when the carbon wire burns the carbon out of both ends and the cylinder stops firing.
