Order Ford NAA Parts Online
Jubilee Hydraulics r__e__a__l slow
BC in MI
11-14-2007 08:53:32
The hydraulics have good power just move REAL SLOW. The speed is not dependent on the weight I'm trying to lift, it is he same loaded or unloaded. Pump was rebuilt last winter and seals in the plate were changed then too.
soundguy
11-14-2007 11:00:15
 Re: Jubilee Hydraulics r__e__a__l slow in reply to BC in MI, 11-14-2007 08:53:32
You don't have gear oil in it do you? it takes aw32/46.. or UTF fluid.. not 90w... etc.
Soundguy
BC in MI
11-14-2007 11:03:04
 Re: Jubilee Hydraulics r__e__a__l slow in reply to soundguy, 11-14-2007 11:00:15
Nope, have thin hydraulic oil. I think it's actually 20w.
Dave in Ms
11-14-2007 09:39:57
Could be something causing a restriction somewhere. A while back an NAA came into the shop that was doing the same thing. The last guy who had it apart used some kind of goo that looked like rubber cement instead of gaskets. The stuff was in all the passages. Cleaned it up, installed new gaskets and seals, and everything worked as new.
