Order Ford 3000 Parts Online
Some 3000's are Diesel powered
awhtx
11-15-2007 19:13:55
The man was decoding the production code for the tractor in the photo which happens to be a gas powered 3000. If you look closely at the photo you can see a carburetor on the engine which is a pretty good indicator that it is a gas engine. If you will look at the first link I posted (labeled Ford ID) you will see that a diesel powered 3000 will have the numeral "1" in it's production code, a gas engine has the numeral "2" and an LP tractor has a "3".
