Front Pump
Charles Story
11-20-2007 05:45:45
third party image
I am having trouble finding an affordable replacement pump for a 730 loader which is mounted to a ford 3000. The FNH dealer wants more than $900.00 for the pump hopefully someone will know where I can find one less expensive. I posted photos in the implement photo section under Pump and hydraulic pump. Thanks
wedge40
11-21-2007 01:39:00
 Re: Front Pump in reply to RodInNS, 11-20-2007 05:45:45
wedge40 said: (quoted from post at 02:37:02 11/21/07) The link below will show everything thats at surpluscenter.
From experience you probably have a vane type pump, which is heavy duty compared to a gear pump. Surpluscenter has some vane pumps, but mostly gear type. They'll both work fine, but the gear pump is said to wear out quicker. If you do a search for vane pump you will find all they have in stock. I check specs on your pump and it's a SAE 2A mount so make sure you get one that matches that.
Link
Sorry that should have been an SAE A mount.
wedge40
11-21-2007 01:37:02
 Re: Front Pump in reply to Charles Story, 11-20-2007 05:45:45
http://www.surpluscenter.com/sort.asp?UID=2007112103232235&catname=hydraulic&byKeyword=yes&search=vane%20pump
tech-tchr
11-20-2007 09:40:41
I got one from american legend tractors about 2 yrs ago. cost under $300 go to ncomplete.com and order their catalog. it shipped in like 2 days.
Jim in NY
11-20-2007 14:06:42
 Re: Front Pump/ RE: tech-tchr in reply to tech-tchr, 11-20-2007 09:40:41
I tried the ncomplete.com address and it came up with music info... do you have a better address for the catalog for H pumps ?
GlenIdaho
11-20-2007 14:46:02
 Re: Front Pump/ RE: tech-tchr in reply to Jim in NY, 11-20-2007 14:06:42
Jim; If you are looking for a Hydraulic pump, try www.surpluscenter.com. They have good pricing and a wide selection.
jim in ny
11-20-2007 16:51:51
 Re: Front Pump/ RE: tech-tchr in reply to GlenIdaho, 11-20-2007 14:46:02
Glen: I was actually looking for the correct address for the catalog from the site mentioned by TECH-TRCH ?
Charlie in Southern IN
11-20-2007 06:48:15
Heres the exploded diagram with a way to decipher the model number.
http://hydraulics.eaton.com/products/pdfs/m2004s.pdf
GlenIdaho
11-20-2007 06:30:42
Charlie; You have a Vickers Vane Pump. You can rebuild it as the parts are available. You'll note that there are three sections. The center section is the "cartridge" which is replaceable. I just bought a new center cartridge that increased the GPM to 11 GPM. Bought new bearings, seals, pins and bolts for $190. That includes a $40 core charge for the cartidge. Send the old one in and you get your $40 back.
Contact Jenni at Pro-Active Fluid Power, 800 398-5733 and she can help dicypher the numbers and get you the parts. I have a sheet that she sent me that will dicypher the numbers. I'll go to the shop this morning and see if I can decode it for you. Whatever you do, don't discard the pump.
john_bud
11-20-2007 06:29:31
Can you post a close up picture of the info on the back of the pump?
Might be helpful jb
Charles Story
11-20-2007 08:10:27
 Re: Front Pump in reply to john_bud, 11-20-2007 06:29:31
I can post a close up photo of pump this afternoon, but I failed to mention spines on shaft are worn real bad.
Joe in MN.
11-20-2007 05:50:44
I don't know where your at -- but in SE Minnesota we have them re-built for about $200 dollars in a hydraulics shop...
Charles Story
11-20-2007 05:56:48
 Re: Front Pump in reply to Joe in MN., 11-20-2007 05:50:44
third party image
I have taken this pump to different hydraulic shops in area Baton Rouge, LA and now one knows anything they say they will research the pump no's the numbers are: V2 1S 128 15A 20 170 LH
FNH dealer had no idea what these number refered to and these are the only numbers on the pump.
If you have a number to a hydraulic rebuild shop I would appreciate it.
old
11-20-2007 08:26:10
 Re: Front Pump in reply to Charles Story, 11-20-2007 05:56:48
Have you checked with suplus supply. They sell a good number of pumps that will replace what you have for a pretty good price. Last time I priced a rebuild kit for a vickers pump it cost more then a new pump did so I have 2 or 3 old vickers pumps laying around
Joe in MN.
11-20-2007 06:16:00
here it is ----- Ronco Engineering Co. ( 507-454-4124 )
1755 Ronco Avenue Winona, MN. 55987
