Order Ford 2000 Parts Online
Ford 2000 diesel
bobsundance
11-20-2007 18:10:50
I got a tractor from friend for 250 dollars. I have spent the time redoing it and it runs great!! But I don't know really what it is as of year. Everyone I have called has been no help. I only know it said Ford 2000 diesel on the side. All the picture I have looked at don't look like mine could someone please help.I can send picture upon request
Richard in La.
11-22-2007 17:21:45
 Re: Ford 2000 diesel in reply to bobsundance, 11-20-2007 18:10:50
I have a 2000 that I bought about 35 years ago for $2000. It has been running ever since. It has a four cylinder overhead valve diesel in it. It takes the same starter as a 1960 model Ford 6 cyl pick-up truck. This starter also fit numerous other Ford cars and trucks around that time.
Old Ford Mechanic
11-21-2007 17:01:33
Ford 2000 Super Dexta.
Don Taylor
11-21-2007 13:33:23
Give this man a try. He works on and sell tractors in various countries.
Don
donaldbritishtractor@sasktel.net
bobsundance
11-21-2007 08:31:08
All the plate says is " A Ford product made in England constructed in all principal manufacting countries"
murn ga
11-21-2007 09:15:09
 Re: Ford 2000 diesel in reply to bobsundance, 11-21-2007 08:31:08
I would guess that you have 2000 3cyl diesel,but I bet it is a Super Dexta Ford 2000 made by Ford in England and imported to the states 63-64.Search for Dexta on the tractor photos and see if this is it.
Larry NCKS
11-21-2007 04:57:48
 Re: Ford 2000 diesel in reply to Jim in NY, 11-20-2007 18:10:50
Have Bob send you some pictures of this thing. Unless it's a late 50s/ early 60s British Fordson it's not from the Ford family. Kinda looks like what I think a Long is, but I don't know. What colors were on a British Leyland?
Brian in MA
11-21-2007 04:27:43
I believe, and I stress believe because I don't have a 2000 but on my 4000 there is a plate inside the hood half that opens. There are several sets of numbers on it. Post those numbers and someone here will tell you exactly what you have. Also, if there isn't a plate on the inside of the hood, I believe on that tractor there are 3 sets of numbers punched into the tranny housing immediately behind the starter. These aren't the cast numbers, but punched into the housing on the flat horizontal surface. Post those and we can decode. By the way, $250 is a screaming deal on that tractor.
john in la
11-21-2007 04:24:38
Dig around on the web site linked and you should find all the info you need.
bobsundance
11-21-2007 08:37:21
 Re: Ford 2000 diesel in reply to john in la, 11-21-2007 04:24:38
I have looked at everything but I do not have the numbers on my tractor. The air filter system looks different and some told me that they think the tractor is from the 50s. LOSO LOST LOST
Larry NCKS
11-20-2007 18:26:43
 Re: Ford 2000 diesel in reply to Double Low Turtle, 11-20-2007 18:10:50
somebody else will have to help you on that one. I'm not that familiar with the later ones and where numbers are, etc.
Larry NCKS
11-20-2007 18:11:32
 Re: Ford 2000 diesel in reply to awhtx, 11-20-2007 18:10:50
there were two different 2000 diesels. The first was built from late '62 to mid '65. It had a four cylinder engine. The second was built from '65 through '74. It had 3 cylinder engine. If you can tell me which one you have, I or someone will be able to tell you how to trace serial numbers down. If all else fails send me a picture. My email is open on modern view.
bobsundance
11-20-2007 18:23:51
 Re: Ford 2000 diesel in reply to Larry NCKS, 11-20-2007 18:11:32
3 cylinder diesel
