Order Ford 600 Parts Online
6600 Hydraulics
Bob Burke
11-26-2007 12:13:31
Need to know where the hydraulic tank is? How many filters? Where there at? How many quarts of hyd oil? Whats the PSI,and also the highest pressure? Thanks Bob
gerard
11-26-2007 16:00:44
 Re: 6600 Hydraulics in reply to Bob Burke, 11-26-2007 12:13:31
Soundguy"s info is correct. I run a "80 6600. Hyd oil filter is behind brake pedal, below quadrant. You ask about PSI. I presume you mean hydraulic psi? Around 2,500 psi, "though I"ve lifted mine to 2,800 by playing with the relief valve. Needed the extra pressure for remote cylinder.
soundguy
11-26-2007 14:19:27
Check your manual.. but many of the x600 units were open sump, and used UTF oil. My late 1975 5000 is that way.
Hyd filters? my guess would be to look under the right floorboard.
My fo-42 manual says between 56 and 60 qts depending if you have the single or dual speed pto... so that sounds like an open sump machine like my late 5000.
Soundguy
