Order Ford 5000 Parts Online
Fuel sender Ford 5000, ohm?
Anders
11-26-2007 23:07:21
Anyone know the ohm range on a fuel sender from a Ford 5000? Going to replace the orginal instrument cluster with VDO gaguges. Fuel sender for VDO calls for a 10-180 ohm? Perhaps the orginal sender is in the same range?
RodInNS
11-27-2007 20:03:13
 Re: Fuel sender Ford 5000, ohm? in reply to Anders, 11-26-2007 23:07:21
I believe it's range is 18-250 ohms if my memory serves me correctly.... and it may not. Why go through all that trouble to change the instruments when a new cluster is probably about 150 bucks?
Rod
JR in nwmo
11-27-2007 00:57:08
Get an ohms meter and check it Rx10. JR
