Firstly, I am new to this forum but finding it very helpful. I have a somewhat lengthy backstory about a project I need some tips on. I am trying to repair/partially restore a tractor for a friend for Christmas. He has never maintained the machine since he bought it second hand more than 25 years ago. No oil/filter change. Nothing. I want to get it in decent running order for him as a present. He doesn"t know anything about my plans, and more disappointingly the tractor, other than he thinks it is a 1955-56. I have found this info on the tractor: front of tractor body says 600 found above and behind the starter - hard to read - 610 or 640 but not 641. Since the tractor has a 4 speed, PTO and 3 point pickup then surely it has to be 640. - under that I see a diamond - then a blurry number, maybe 7 - then 4376 diamond. so 74376 makes it a 1955 right side of engine case - EAE-6015-F on top of valve cover - blurry - 310098 As far as I can tell this info points towards a 1955 640. A problem arises as the tractor is blue. I cant tell if it is originally blue but the owner says it may have been painted. He remembers gray which would make sense. I thought blue did not come around until 1963? The tractor is in bad shape. A few details are wide front as opposed to tricycle. Rubber wheels. Not offset. Don"t know how to tell if it is cartridge or spin on oil filter. I haven"t removed the case to see what I expect to be cartridge. I can remove the center bolt but I cant tell how to remove the case. Exhaust is rusted to pieces. Thinking of replacing entire manifold and exhaust. Carb needs rebuild, electronics need replacing, hydraulics are shot and fluid is in dire need of replacing, and the tank needs a good cleaning/sealing. Have you had any luck sealing tanks? Any tips on a positive identification would be great. Any general help or suggestions is greatly appreciated as this is the first time I really put some effort into restoring/repairing tractors. Thanks ahead for the help. Thanks for listening.
