Order Ford 4000 Parts Online
fORD 4000
Charlie C.
12-02-2007 10:12:10
Hi All, you guys have been a help in the past so here is one more question.
I have read that for three point hitches there is a standard measurement from lifting pin to lifting pin and now I can't find where I read that.
What is the measurment on the 3PH?
I am gathering material to make a back blade for my tractor and would like to make this blade so that it could be used on other tractors.
Thanks for your information
Charlie
Charlie C.
12-02-2007 16:49:18
 Re: fORD 4000 in reply to Charlie C., 12-02-2007 10:12:10
Thanks Tim, The link was where I must have seen the information. Old yes I could just go buy one but what fun is that.
third party image
I have most of the material already, I usually will take any metal that I am given so that I can make tools like the back blade and ect.
Thanks for the help fellows.
Charlie
old
12-02-2007 11:39:32
You will find it cheaper in the long run to buy a back blade. Watch the auctions and you can pick them up for less then $100. Or you can buy them new for around $300-500 and that is less then what you will have in one if you try to make it your self.
Tim in MN
12-02-2007 11:16:08
Look on the left side of this page under "Research & Info" & "3-Point Specs", in the first line there is a link to more 3-point info which should give you the dimensions you need.
