Order Ford NAA Parts Online
jubilee hydraulic problem
boler76
12-02-2007 11:29:17
Parked my Jubilee one day and the next day the 3pt will not raise, It has a vane pump, Put air pressure to dipstick and still no oil came out of the 3/4" plug were pressure line enters housing, Do the vane pumps quit just like that ? It was working strong till this point, Any and all info appreciated Thanks Jim
Joe(TX)
12-03-2007 04:34:28
 Re: jubilee hydraulic problem in reply to boler76, 12-02-2007 11:29:17
It could be one of the valves in the lift cover stuck. I had one do that. I had to tap on the cover sometimes to get the lift to work.
old
12-02-2007 11:36:57
Pull the little plug out of the pump and fill with oil. Put the plug back in and try it. I never like to use air because that can cause air locks in the system. How cold is it?? If cold it may take a few minutes for things to work. When cold out it takes my 841 5 minutes or more to start to work as they should
