2N Is there a thrick to installing the stater
TOM from Beale
12-03-2007 18:00:25
I donot know if bendicks is not in far enough .it is the long shaft starter with bendicks at the end .It hits flywheel and set at angle the teeth are a 1/2 " from end spring can someone tell me or show me what the bendick should look like ?
soundguy
12-04-2007 06:10:14
 Re: 2N Is there a thrick to installing the stater in reply to TOM from Bealeton VA., 12-03-2007 18:00:25
If you are saying that you are having trouble getting the starter bendix past the flywheel for reinstall, then: have you removed the block drain petcock so that the starter end can touch the block?
Is there an elongated opeing at about 2'oclock onthe starter mount hole that someone relieved to help get the starter back in? if not.. still try to angle the bendix to that position to help it clear the flywheel.. it's tight and you can't see inthere.. but it will go in.
post back if this was not what you were asking.
soundguy
Soundguy
8N'r--WI
12-04-2007 05:59:24
Yes--compliments of Bruce (VA) on the N Board.
To remove the starter, unscrew the bolts out of the block & put a nut on one of them. Otherwise, the starter comes apart. Not fatal, but not fun either. Then, loosen the two bolts holding the oil filter canister to the block, remove the dipstick, and keep the starter close to the block while pushing the front of it down and lifting the back up. Sometimes you have to remove the drain petcock as well.The bendix is behind the flywheel; your job is to get it over the flywheel. To install the starter, keep it close to the block while pulling the front of it up and pushing the bendix back into the hole. The bendix has to go behind the flywheel; your job is to get it over the flywheel. Grinding out an egg shape at the 2 o'clock position before you put it back will make your life easier.
Lastly, while the starter is off, polish the block & starter mating surfaces w/ sandpaper to insure a good electrical ground between the two, and clean the mating surfaces where the starter's "belly" meets the aluminum endbell. The starter's ground circuit is through that "joint" as well was through the starter endbell-to-flywheel housing joint.
Tim
Bob
12-03-2007 21:23:49
 Starter Drive Bendix in reply to TOM from Bealeton VA., 12-03-2007 18:00:25
I'm not much help as I'm REALLY tired, and you post apparently doesn't make as much sense to me as it does to you!
You'd probably have better luck posting on the "N" Board, or searching the archives over there.
