Order Ford 4000 Parts Online
4000 Ford Tractor Clutch Stuck
Archie Miller
12-09-2007 19:11:10
I have a 4000 ford english 3 cyl diesel 8 speed trans. Was using the tractor stopped it for about 2 hours went to use it again, clutch was stuck. Tried adjusting but no luck also tried pulling it with another tractor. Help please
RodInNS
12-09-2007 20:51:30
 Re: 4000 Ford Tractor Clutch Stuck in reply to Archie Miller, 12-09-2007 19:11:10
In all likelyhood the pinch bolt that holds the release lever to the clutch cross shaft has broken or there is some other problem with the release bearing. Probably easiest to split it and get on with life.... That's not a difficult tractor to split.
Rod
old
12-09-2007 19:36:02
As John said if its cold enough. Or something may have broke inside of it. I don't know that one well but you might be able to pull the starter and look inside to see if things are working as they should be. Also pulling it with another tractor will do little to help pop one free but driving it will.
john_bud
12-09-2007 19:29:09
Is it below freezing? Could have water frozen in there. That would happen in 2 hours.
jb
Archie Miller
12-09-2007 19:58:47
 Re: 4000 Ford Tractor Clutch Stuck in reply to john_bud, 12-09-2007 19:29:09
Thanks guys was in the 80's. will pull starter and also try getting it in gear guess i could push it to start it.
old
12-09-2007 20:38:14
 Re: 4000 Ford Tractor Clutch Stuck in reply to Archie Miller, 12-09-2007 19:58:47
No need to push start it. Put it in a low gear and then if it has a starter switch like to older fords just short it to ground. Now if it doesn't have that type then not sure unless it doesn't have a safety interlock. You can also spray brake cleaner in and around the clutch if its caused by rust/grease problems. My 8N will lock up like that if it sits for more then a few hours so I block the pedal down when I'm not using it
Archie Miller
12-10-2007 05:52:45
 Re: 4000 Ford Tractor Clutch Stuck in reply to old, 12-09-2007 20:38:14
Great idea Hobby Farm Thanks
