Tranny Switcheroo
Allen Hunt
12-11-2007 20:03:16
I've asked before about putting in a 4-cyl. Ford 2000/4000 clutch into an 881. I'd been thinking that I had to use a 540/1000 transmission to replace the 540/1000 I have now in the 881. So...the question is:
Can I switch a 4-cyl. Ford 2000/4000 540 only SOS tranny into an 881 which now has the 540/1000 SOS tranny. If this is okay to do, is there going to be a problem in the rear end for the pto after the switch?
Thanks for your input in advance!!!
Allen
JimAg
12-11-2007 20:54:16
 Re: Tranny Switcheroo in reply to Allen Hunt, 12-11-2007 20:03:16
Not a problem. The transmissions will swap out without a problem. As for the PTO shaft or the end adapter, just use the complete shaft for the SOS with 540 only, or use your 540/1000 shaft with the 540 end. The hook-up inside the tractor is the same for both shafts and transmissions. Jim
Allen Hunt
12-12-2007 13:30:18
 Re: Tranny Switcheroo in reply to JimAg, 12-11-2007 20:54:16
Jim, Thanks for your reply!
Allen
Allen Hunt
12-12-2007 13:25:47
Allen
