Order Ford 4000 Parts Online
4000 power steering
Withers
12-10-2001 11:47:29
I have 3 cyl diesel 4000 that is leaking power steering fluid out of the top of the steering column under the steering wheel. Does anyone know where the seal is that would be causing this? Also the rear axle seal is leaking. What is involved in changing it out?
RickB.
12-10-2001 17:42:18
 Re: 4000 power steering in reply to Withers, 12-10-2001 11:47:29
Rear axle seal R&R involves removing the wheel, axle housing, brake assembly, planetary, and axle shaft. Best to get a repair manual, or hire it done. It is no fun the second time. Replace the brake rod boot as well.
hv-ga
12-10-2001 13:46:50
On the 3000 there is an oil seal in the base of the steering column where it bolts to the valve spool. What I'm calling the steering column is the first section the steering wheel is resting on. Once you remove the column, replacing the seal is a pretty straight forward job. You might find, as I did, that the cause of the problem is a faulty check valve in the spool. Good luck. hv
Withers
12-11-2001 12:38:29
 Re: Re: 4000 power steering in reply to hv-ga, 12-10-2001 13:46:50
Thanks for the info guys. It's folks like you all that makes my life easier.
