I don't know too much about the TW series tractors but I can't imagine that they were too different from the 10 series of that time which I do know quite well. First off, I wouldn't worry about a second battery. You appear to be fairly far south??? so the 4DLT should suffice well enough. Check the cables. Use crimp on ends rather than the bolt on replacements. Keep good big 2 aut cables on it with clean connections. The starters need their ground lug tightened periodically. If that doesn't help and it's a lazy turner, haul the starter off and take it to a starter shop for a brush and bushing job. Those are no expensive to keep going IF you have a good shop that knows to fix those things rather than rip you for a full rebuild. Stick an AC Delco battery in there if possible... Re: the instruments. I didn't know that Ford used an oil pressure gauge on any of the tractors. I thought that they only used idiot lights...Sure it's not an aftermarket gauge of some sort? The temperature gauge could be a wire problem from the gauge to the sender, a power supply problem to the gauge, or a bad sender. I forget which way the gauge will peg if you ground it, but I think it goes hot. Try that and if it responds properly I'd expect a bad wire or bad sender... I believe you can get RedTek kits to seal and recharge the air and seal th leaks. The truck supply shops should have them. If not get somebody to find the leaks and fix them... I don't think you'll find any problem with the rockers moving either... The tight screw seems to work quite well here. The cabs can be a lot fo work to fix tho... I've got one here that needs a lto fo work now and it won't be much fun. I knwo of guys that did fix them and it's a lot of work with a mig... If you get all that stuff fixed you might find it quite a good tractor, and one that's a lot more miserly on fuel that those beloved Deere's you talk about. Rod
