Order Ford 4000 Parts Online
Wheel weights will the 4000 weights fit on a 851?
Joe)NYC)
12-18-2007 06:54:32
Someone has a 4000 machine that needs a lot of work(engine)but has with wheel weights(pie type) and a loader and probably other useful stuff. I would like try to see if he would part with the weights but I need to know if they would fit my 851 without any modification. Also what does a set go for in NY state? Thanks.
Joe)NYC)
12-19-2007 06:29:40
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Joe)NYC), 12-18-2007 06:54:32
I got a reply from the advertiser of the 4000 machine. He si saying that the machine belongs to someone without a computer and is advertising for him. Also says that if the owner ever decides to sell the weights separately the HE will buy them himself. So I guess I am not lucky this time. Thanks for all your replies.
Joe)NYC)
12-18-2007 19:28:25
Thanks to all for the replies. I will keep you posted if I wid up taking them home.
Joe in NYC.
Jim.UT
12-18-2007 12:59:22
If he agrees, make sure you also get the wheel stud extensions. You might need to go prepared with a set of standard lugnuts so you can replace the stud extensions with lugnuts. That way his rear wheels won't fall off after you're done!
Joe)NYC)
12-18-2007 19:38:58
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Jim.UT, 12-18-2007 12:59:22
Jim UT,
My tractor is 240 miles away from me right now and cannot look at it to see what you mean by 'standard lugnuts', 'stud extensions' and 'lugnuts'. Are there two separate sets of bolt/nuts-one to hold the rim on tractor and one to hold the extra pie weights? The 'standard lugnuts' you mention I need to bring with me, is this a bolt and nut setup? I will have to look at my shop manual and se if that can show me something. Thanks.
Joe in NYC
Jim.UT
12-18-2007 20:12:45
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Joe)NYC), 12-18-2007 19:38:58
third party image
third party image
Here are some photos of some stud extensions. They thread onto the tractors rear wheel stud in place of lugnuts. They perform a dual function:
1. they act like lugnuts to hold the wheel on the tractor
2. they provide a place to mount the pie weight mounting plate.
So, you see, without the stud extensions, you have no way of mounting your pie weights to your tractor. Many times the extensions get left on the tractor when the weights come off because they are still needed to perform function #1. Then the poor slob who buys a "complete" set of pie weights is stuck buying new extensions at up to $20 a pop.
However, in order to remove the stud extensions from the 4000 donor tractor, you will need a set of standard lugnuts (like you have on your tractor now) to replace them and perform function #1. I have several lugnuts that I'd sell for $1 each....$16 for a full set, plus $5 shipping via Priority Mail if you need a spare set. Email me if you want to discuss it.
Joe)NYC)
12-19-2007 06:25:07
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Jim.UT, 12-18-2007 20:12:45
third party image
Jim,
Here is a photo of the rear wheel on my 1958 ford 851. I sent you E-mail regarding the extra lugnuts you have. Thanks.
Jim.UT
12-19-2007 09:19:43
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Joe)NYC), 12-19-2007 06:25:07
third party image
You do not have power adjust rims. Any set of pie weights will fit your wheel.
I found a better pic of power adjust rims on an ebay auction. This one has the 30 lb weight set attached.
RickB
12-19-2007 02:37:18
When I installed my weights, I used my existing lug nuts to mount the weight disc to the extension studs. Weights, plates, and studs are all that's needed.
Jim.UT
12-19-2007 09:21:25
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to RickB, 12-19-2007 02:37:18
Yep, you're right. The existing lugnuts will be needed to attach the mounting plate to the stud extensions. So he'll need another set of lugnuts to trade with the guy if he pulls the extensions off the 4000.
RickB
12-19-2007 15:15:48
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Jim.UT, 12-19-2007 09:21:25
I must be thickheaded or something. I didn't need "extra" lugnuts when I bought my pie weights. I took off my lug nuts one at a time and replaced them with adapter studs. Then placed the mounting plate on and fastened that to the adapter studs with my own freshly removed lugnuts. Why should I need "extra" lugnuts??? I didn't get lugnuts with the weight set, and so far as I know, I still don't need them.
Jim.UT
12-19-2007 16:16:00
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to RickB, 12-19-2007 15:15:48
There is no need for an extra set of lugnuts when you install weights on your tractor. But you need to realize that the situation we've been discussing is pulling a set of weights off another tractor.
So, picture this: you find a 4000 for sale that has a set of pie weights. You want the weights but you dont' want to buy the 4000. So you ask the seller to sell you just the wheel weights. He says OK.
So you start to pull the weights off the 4000. When you get down to the extensions, which you also need, you will need an extra set of lugnuts to put on the 4000 IN PLACE OF the extensions you are about to remove. Otherwise, the rear wheels will fall off the 4000. Clear now?
RickB
12-20-2007 03:14:09
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Jim.UT, 12-19-2007 16:16:00
In that case, I'd just use the lugnuts that held the plates to the adapter studs on the donor tractor. Leave his wheels firmly attached, and go home to use my lugnuts on the newly purchased adapter studs. Don't even need a jack to do the disassembly or asssembly. I just saved you the cost of 16 lugnuts.
Jim.UT
12-20-2007 08:35:07
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to RickB, 12-20-2007 03:14:09
OK, now it's my turn to slap my forehead and say "Duh".
I guess my problem is that I've always been talking to people that have just the stud extensions on their tractor, but no weights. When I try to offer to buy the extensions, I have to have a set of lugnuts to trade.
With a full set of weights being removed, you're absolutely right. No need to have a spare set of lugnuts. Sorry to be so dumb.
RickB
12-20-2007 14:25:22
 Now I understand your view. in reply to Jim.UT, 12-20-2007 08:35:07
Funny how many times we expect others to follow the same train of thought we are. All to often (as in this thread), that is not the case.
RickB
12-20-2007 14:25:21
RickB
12-20-2007 14:25:20
John O (MI)
12-20-2007 05:37:56
I agree with you Rick. No "extra" lug nuts are required. I remove and install my pie weights every year (winter use only), and do exactly as you said. The same lug nuts are used in each situation, its just a matter of where.
They only time I've needed an extra set of lug nuts is when I install the wheel spacers that came with the power adjust rims.
-John
Dean
12-18-2007 09:04:14
Joe:
If the 4000 has 4 cylinders, the weights will bolt right onto your 851 so long as the 4000 does not have a heavy set of weights and your 851 has power adjust rims. If your 851 does not have power adjust rims, any of the pie weight sets will bolt on.
Pie weights come in several varieties and prices vary by region and variety so value cannot be estimated with the available information.
That said, I have seen complete pie weight sets sell from $150 to $650.
Dean
Joe)NYC)
12-18-2007 18:16:37
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Dean, 12-18-2007 09:04:14
Dean, I don"t know if I have power adjust rims. How can I tell if I do/not have them? According to the picture in the ad the weights are pie shaped and there are 12 pies per wheel.
Jim.UT
12-18-2007 20:34:07
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Joe)NYC), 12-18-2007 18:16:37
third party image
Power adjust rear rims were an option...some sources say they were standard on Powermaster tractors.
Here's a photo of an 851 that I lifted out of the tractor gallery. It has power adjust rims. Look at the center disk of the rear wheel. You'll see that it is attached to the rim at 4 points. Those 4 points are grooved brackets. The center disk rotates inside the rim (inside the grooves in the 4 brackets) to screw itself in or out to adjust the wheel track width.
Non-power adjust rims will have a center disk that is bolted to the rim in 6 places.
This becomes important when buying pie weights because the pie weights came in two versions. The "light" set contained 12 segments per wheel that weighed 30 lbs each. The "heavy" set also contained 12 segments per wheel, but they were bigger and weighed 45 lbs (I think) each.
The heavy set WILL NOT FIT on a power adjust rim. So if you have power adjust rims, you need to make sure the weight set you buy is the ligher (smaller) set.
If you do not have power adjust rims, either the heavy or light set will fit fine.
Brian in MA
12-18-2007 07:21:21
What vintage is the 4000? I am in need of a donor 4000 for an 8 speed tranny and rear end. One with engine problems would be perfect.
Joe)NYC)
12-18-2007 18:18:38
 Re: Wheel weights will the 4000 weights fit on a 851? in reply to Brian in MA, 12-18-2007 07:21:21
Brian, this 4000 has the dreaded SOS tranny.
Ultradog MN
12-18-2007 07:11:36
Joe,
Yes those weights will fit.
The rear bolt pattern is the same from the 8N all the way up through the 3 cyl 3000 tractors.
