Paul; here's some info on static timing your 850 courtesy of contributor "Dean". With regards to your points they are to be set at .024 to .026 (per manual). Some will set them at .015 or .016. A feeler guage is inexpensive and easy to obtain. "Static timing is how one times an engine without a timing light. It works well if your distributor is not badly worn. Here's how to do it: After setting the points, crank the engine over until the rotor points to the #1 plug wire. Now turn the engine using the fan or a screw driver on the ring gear until the timing pointer is aligned with the 4 degree BTDC mark. Remove the #1 plug wire from the plug and connect it to another spark plug so that you can see when it sparks. Lay the spark plug on a metal engine component so that it is grounded. Loosen the distributor and turn the ignition on. Turn the distributor clockwise a few degrees until the points close. You can tell when the points close by watching the ammeter. Slowly turn the distributor back counter clockwise until the plug sparks and tighten the distributor making sure not to allow it to move. Your engine should now be timed within a degree or so of what you can do with a GOOD timing light."
