Order Ford 800 Parts Online
Ford 8000 38 tires and turbo's?
Andrew Schutze
12-20-2007 05:26:32
This message is a reply to an archived post by Stacy on May 02, 2003 at 19:56:32.
The original subject was "Ford 8000 38 tires and turbos?".
It is not that hard to do either. You can put a turbo from a 9000. Or did what I did I picked one up from a puller that order a new bigger one. You just need to make a plate that goes from your turbo to your manifold. that is the hardest. oil lines are easy too. bigger the better specially return. keep the pressure side for the oil on top. You can get adapters for going to 38s. best to buy wheels.
