Order Ford 861 Parts Online
Ford 861 transmission parts
Bobby Vaughan
12-21-2007 12:02:32
Ford Tractor 861
172 cid engine
5 speed transmission I need the following parts for the above xmission.
p/n NDA77100A Reverse gear
p/n NDA7137A Third gear
p/n NDA7106A Coupling Center Shaft Connector.
May be new or used. If used must be in good condition. No significant wear on edges. (This is why I am replacing. Jumps out of gear when unloaded.)
Also need a xmission overhaul gasket set with seals and a differential gasket set with seals.
Please quote price and shipping with any response.
awhtx
12-21-2007 19:03:43
 Re: Ford 861 transmission parts in reply to Bobby Vaughan, 12-21-2007 12:02:32
My 861 was jumping out of 3rd when I bought it and I got a good used sliding coupling from Alexander's Ford Tractors in Winnsboro, TX. I got bearings and seals from Purvis Bearing. I got the gaskets from San Saba NH.
soundguy
12-21-2007 13:47:30
If you are having jumping out of gear problems.. aslo check your 3 detent plungers.. if they are worn, they do not give a good click-in / click-out feel when you shift. cheap and externally replaceable.
CNH carries many new parts for these machines.
Soundguy
