850 carb filter
Air Force One
12-21-2007 16:03:55
The gas line that connect from the tank to carb...is there a filter between the fuel line and carb? I know there is one in the tank, one in the sediment bowl...thanks
GlenIdaho
12-21-2007 16:26:10
 Re: 850 carb filter in reply to Air Force One, 12-21-2007 16:03:55
Hi Paul; No, there is no other inline filter besides the screen at the fuel tank shut off valve and the screen in the sediment bowl.
soundguy
12-21-2007 22:13:32
 Re: 850 carb filter in reply to GlenIdaho, 12-21-2007 16:26:10
No elbow screen?
Soundguy
GlenIdaho
12-22-2007 04:37:43
 Re: 850 carb filter in reply to soundguy, 12-21-2007 22:13:32
Hey Soundguy; My book shows the elbow screen to be for the LP and Kerosine engines and not the gas rigs. My 850 does not have an elbow and screen. If I recall correctly, Airforceone is running a gas engine. Am I missing some info somewhere?
Air Force One
12-22-2007 05:50:00
 Re: 850 carb filter in reply to GlenIdaho, 12-22-2007 04:37:43
no elbow screen on my 850 gasser
soundguy
12-22-2007 13:40:08
 Re: 850 carb filter in reply to Air Force One, 12-22-2007 05:50:00
Odd.. mine has one.. but it also has had the sed bowl removed at the carb as well.. my guess is the prev owner needed to match the fittings and found the elbox screen was the ticket when he farmerized the gas line..
soundguy
GlenIdaho
12-22-2007 15:31:53
 Re: 850 carb filter in reply to soundguy, 12-22-2007 13:40:08
Hi Soundguy; I guess that explains it. It just goes to show you have to be careful with these old tractors as to what is original and what is not. You had me doing some double checking. Thanks for all that you contribute here. I appreciate your knowledge and experience.
soundguy
12-22-2007 20:50:06
 Re: 850 carb filter in reply to GlenIdaho, 12-22-2007 15:31:53
I had considered putting it back stock.. but never got around to it as it is my work tractor... thus never paid much attention to what was plumbe dinthere.. elbow screen must have bene the fitting the prev owner needed.. though i do wonder why he removed the sed bowl in the first place.. they work pretty good.
soundguy
GlenIdaho
12-23-2007 07:09:45
 Re: 850 carb filter in reply to soundguy, 12-22-2007 20:50:06
You know, in thinking about it, you know how sediment bowls will sometimes leak if you don't have the gasket just right, this is a good fix.
soundguy
12-24-2007 13:50:09
 Re: 850 carb filter in reply to GlenIdaho, 12-23-2007 07:09:45
Yep.. he probably got tired of seeing gas drip of fthat sed bowl one day and then just removed it and plumbed the line straight however he could.
Soundguy
