FORD 1700 locking differential
BEWILDERED
12-23-2007 18:29:04
Does the 1700 have a rear differential lock? If so, does anyone have any pictures of what it looks like inside and ideas on why it would not work?
Thanks
TIMBER JACK
01-08-2008 16:25:07
 Re: FORD 1700 locking differential in reply to BEWILDERED, 12-23-2007 18:29:04
I have the same tractor and my lock does not work. Did you get yours to work ? and could you please email me with the pictures. thanks
BEWILDERED
01-10-2008 06:02:53
 Re: FORD 1700 locking differential in reply to TIMBER JACK, 01-08-2008 16:25:07
Send me your email and I will forward what I have. This was a job for a friend and he decided not to work on it in the winter. No garage.
farmboy@comcast.net
BEWILDERED
12-24-2007 04:27:01
Thanks to all and to all a Merry Christmas. I should be able to help my neighbor now, with this info. Thanks Again
Oliver in SC
12-24-2007 04:08:47
Several reasons why it won't work. The diff lock gears may be worn, the fork may be bent, etc. You have to be stopped or moving slowly when you step on the lever to engage. Check your mail, I can send you a picture and parts list for the 1700 diff lock.
c65truck
12-24-2007 02:51:41
diff lock is the L shape bar behind your right heel .I have a 1700 but don't have any pictures of the inter working of one. you would need a service manual
Old Ford Mechanic
12-23-2007 21:30:20
I'm not familar with the small Ford tractors but,if it has a diff lock there should be some sort of foot controlled lever to activate it.Most likly on the right side next to your heel.
paul
12-23-2007 21:43:54
 Re: FORD 1700 locking differential in reply to Old Ford Mechanic, 12-23-2007 21:30:20
Little T bar you put your heel on on a 1720. 1700 is 2 generations older, would expect some foot bar there.
--->Paul
