Order Ford 3000 Parts Online
3000 tach cable
hv-ga
12-12-2001 02:41:27
I need to install a new tach cable. I noticed the metal housing that attaches to the generator has a gear inside with the old cable attached. But the gear appears to be frozen in place and is somehow attached to the old cable. The new cable does not include the gear. Anybody have any experience with repairing these things. Thanks
RickB.
12-12-2001 17:10:36
 Re: 3000 tach cable in reply to hv-ga, 12-12-2001 02:41:27
Remove the right angle tach drive from the generator. If the worm gear on the gen's armature is OK, get a new tach drive from a New Holland dealer.
hv-ga
12-13-2001 02:33:06
 Re: Re: 3000 tach cable in reply to RickB., 12-12-2001 17:10:36
The generator shaft and the right angle housing are fine so I ordered just a new cable which was cheap. But I think you're right, the whole deal probably needs to be replaced. There does not seem to be a way to remove the old cable from the right angle housing. Thanks.
