ford tractor will not start
gene walkowicz
12-26-2007 17:06:00
I have a ford tractor i thank a 9n that will not start. It will trun over ok but that is it. I do not know any thing about them. it does not have a key switch, push button start, also has two other pull/ togle switches no combimation seams to start it it is 6 volt, has a magneto does not seam to have a spark at the spark plug. I am youes to a dis/coil and points. but not a mag please help
Bob
12-26-2007 22:02:24
 Does it REALLY have a mag??? in reply to gene walkowicz, 12-26-2007 17:06:00
The distributor used on these tractors is "odd-looking", and often mistaken for a mag.
Third Party Image
Magneto
Third Party Image
"Front-Mount" distributor
gene walkowicz
12-27-2007 07:17:03
 Re: Does it REALLY have a mag??? in reply to Bob, 12-26-2007 22:02:24
Well thanks for the photo now i no it is a front mout dis set not a mag so i uess i will try to do a simple turn up can you tell me best spark plug to use a gap for theem and the points. My grand dad past away a year ago and it was his,it has set two year I need two get running so I can move it to my place. Thanks for the help you all have given me.
Bob
12-27-2007 13:47:13
 Distributor service instructions... in reply to gene walkowicz, 12-27-2007 07:17:03
Cehck out the site linked below:
Dell (WA)
12-27-2007 10:04:18
 Re: Does it REALLY have a mag??? in reply to gene walkowicz, 12-27-2007 07:17:03
Gene..... .the weird 4-nipple frontmount distributor is a 2-bolt 15-min job to remove and adjust the points to 0.015" on the kitchen table. Caution: the SHORT 3/16-32 screw gitts INVISIBLE wear and slips. Best sparkies are AutoLite 437's gapped 0.025..... ..Dell, yer self-appointed sparkie-meister
old
12-27-2007 08:17:43
Most people swear by the auto lite 437 plugs. The easy way to do the tune up is to remove the distubutor by takeing out the 2 hold down bolts and then install your points etc on a table. The distubutor will only go on one way unless forced and if you force it you will brake it. Never a worry about getting out of time in other words
gene walkowicz
12-30-2007 19:23:05
 Re: Does it REALLY have a mag??? in reply to old, 12-27-2007 08:17:43
Ok got my tractor running to day first time it has ran in over 3 years was glad to hear it run. Thanks for the help dell, bob, and old. My next thing to work on will be the wiring as it has some wires that goes know were. Then we will need to look at the brakes. thank agian gene
awhtx
12-26-2007 17:41:03
 Re: ford tractor will not start in reply to gene walkowicz, 12-26-2007 17:06:00
A magneto is simply a self-contained distributor and coil along with some magnets to generate electricity. It has points just like a distributor. If it is not firing you either have defective or mis-adjusted points, a defective coil, a defective cap or a defective rotor. I'd start the diagnosis by removing the cap and turning the engine over. Do the points open and close? Do you see a spark jumping across them? Start with the basics and work your way down line.
