To do or not to do ,but I did
58frog
12-27-2007 16:12:46
Ive been playing with this naa Ive got for a few months know and Its running great at his moment in time ,but I was wondering if I might damage the valves by doing this ..... ..The new plugs I put in auto lite 295s fouled out with oily carbon when i refilled the tank after sealing it ,so i got some 303s,a little hotter .we she ran as nice as a farmall 4 banger HEHE.
Then they craped out ,ran like moisture,fouling ,it was the same sinario etc you guys know what Im talking about.Well I thought these plugs are new and Ill make them work,so I put an accel super coil with ,im assuming built in resister on the old girl and never touch the plugs that were fouled .This ford runs the a new machine,well no quite, I have only to enjoy turning the key and she always starts.what about them valves or pistons ?
..... .....By the way There is a brandy spankin new zenith on her and its adjusted
john_bud
12-27-2007 18:29:03
 Re: To do or not to do ,but I did in reply to 58frog, 12-27-2007 16:12:46
The hot plugs and the super hot coil are giving a much much larger and hotter spark. That may be masking a root cause for the fouling. You may have bad valve seals allowing oil into the cylinders. Or low compression (what is it by the way?). Or maybe even bad or broken oil rings.
At least check dry and wet compression and see.
But I don't think the plugs and coil will hurt anything.
jb
58frog
12-28-2007 17:33:21
 Re: To do or not to do ,but I did in reply to john_bud, 12-27-2007 18:29:03
Thanks for the info JB
