Order Ford 3000 Parts Online
3000 hydraulic lift problem
hv-ga
12-14-2001 17:40:40
Yeaterday my 3 point hitch seemed to work fine although it would leak down after a two or three day period without any implement attached. Today it won't work at all. Won't raise, won't do anything. I changed the fluid two weeks ago and there are no external leaks. I did not use ford fluid but the dealer said the fluid I bought was compatible. This tractor has the auxillary two spool remote hydraulics which I've never used. I noticed that as I move the control lever up it seems to bind slightly as you get to the the top and the draft control lever moves as the control handle is moved. The flow control knob is adjusted all the way in. I have not fiddled with or worked on the hitch at all. it just quit working. Well, I did pressure was the tractor today but that's all. Help! Thanks.
