1947 2N
Newton
02-16-1999 19:45:37
Looking for detailed manual containing crankshaft
journal specs,detailed removal and installation of
.040 cylinder liners.
bg
02-26-1999 23:06:17
 Re: 1947 2N in reply to Newton, 02-16-1999 19:45:37
Crankshaft JournalDiameter- 2.248-2.249
Get an I&T FO-4 manual, if you can find one(they have been out of print for several months).
I'd take the block to a machine shop that unless you know about such things. I'd go ahead and bore the block and install the cast-iron sleeves, rather than mes with the hardened steel sleeves.
They can be rebored at least once on subsequent rebuilds, and in my opinion, are much more satisfactory than the steel sleeves.
ZANE
02-17-1999 12:44:47
Their is a tool that you can use to drive the sleeves out of the bore with.It is best to have the crankshaft removed to insure that you don't damage the journals by striking them.you could have a maching shop fabricate one by turning a piece of round stock just a little larger than the bore of the cylinders.Firts turn a piece of stock of about 3/4" to about .020" smaller than the bore, then turn half of the blank to about .020" smaller than the bore of the sleeves.Cut about 3/4" from each side of the turned driver so that it will go into the bottom of the sleeve and with a 10 or 12 lb hammer and a large drift against the tool drive them out the top of the cylinder.
If you are a pretty good welder their is an easier way to get the old sleeves out. Lay the block on it's side and with a 6011 1/8" rod run a cold bead from the bottom of each sleeve to the top.Do this about 3 times in each sleeve and allow them to cool to the touch.You can then either pull them out with your hand or catch the bottom edge with a large screwdriver and tap them out. Be carefull not to weld through the old sleeve. After you get the old sleeves out lightly hone or sand the bore where the heat from the welding may have cooked the carbon to the bore slightly.Don't hone much. The new sleeves must have a .005 interference fit.
Don't try to drive the new sleeves in with the tool that you fabricated to pull them out with as that tool will split the sleeves when you try to drive them back in.
You can take a piece of flat plate of at least 1/2" thick and that will completely cover the top of the new sleeve plus about 1" or so and drive the new sleeves down till they are even with the deck of the block.Some of these N guys will tell you to freeze the sleeves etc but it is not necessary.I have done literley hundreds and I quit that freezing bit years ago. Can't tell the difference.
Ask on the N page about the specs for the crank.I don't know what they are I have forgotten.
Link
You could also call the local automotive machine shop in your area and they could give you this data.
Zane in Alabama.
Newton
02-17-1999 19:27:47
 Re: Re: 1947 2N in reply to ZANE, 02-17-1999 12:44:47
I am in the early stages engine O/H, if main bearing journal size was originally 2.2485 what
is "standard" bearing size? Assuming standard
bearing size to be 2.250,would a .010,.020,.030,
.040 undersize bearing be 2.240,2.230,2.220,2.210
respectively? My crank measures 2.235,do I use .010 under bearing or a .020 under which would require ginding crank ?
ZANE
02-19-1999 19:53:23
 Re: Re: Re: 1947 2N in reply to Newton, 02-17-1999 19:27:47
It looks to me like you are .0125 under standard. That is to say 12 and one half thousands.You could probably get by with the .010 bearings.I doubt that it has worn this much from standard.It probably has .010 bearings in it now.If it had worn as much as .010 or more the crank will not be round.Measure it all the way around. If it is out of round as much as .002 it should be turned.(ground).Unless the bearings are the standard Ford bearings they should be marked on the back side as to the size.
