Order Ford 640 Parts Online
Removing Ford 703 Loader from Ford 640 Tractor
300 Mag
01-09-2008 17:08:43
In the near future, I am going to remove the Ford 703 (19-105) loader from my '57 Ford 640. I have to pull the head on the engine, and the loader is in the way. I have the original Ford Assembly and Operation manual, but doesn't give much info reguarding removal. It doesn't look to difficult, only a few bolts to remove and some pins.
However, I am not sure how to correctly detach the pump. How do I detach the pump for the tractor? This will be my first time removing a loader and any help would be greatly appreciated!
671DKS
01-10-2008 09:41:15
 Re: Removing Ford 703 Loader from Ford 640 Tractor in reply to 300 Mag, 01-09-2008 17:08:43
unless you shaft is threaded like my 671 in which case those threads will be left handed. good luck, Kent
awhtx
01-09-2008 18:09:45
Unbolt the pump from the loader frame and move it forward (away from the tractor). The shaft between the crankshaft hub and the pump hub is splined on the crankshaft end and will slide out of the hub.
