Vaccuum
Larry NCKS
01-10-2008 09:04:25
Amatt said: (quoted from post at 11:52:33 01/10/08) You may be right Larry. I wasn"t claiming that it worked, but that the vacuum was the theory behind it, at least originally. I thought I read it in my I&T, but maybe I read it on some obscure website (not ytmag.com).
I not only may be, I am right!!!! Think for a minute. What component would create this vacuum? How could it work in a system where the dogbone (pushrod) simply rests against the piston and is not attached to it? Even if the piston could be sucked in (which it can't) what would pull the dogbone in?
Vacuum and making the implement suck deeper was never even a part of the theory of the operation of the Ford/Ferguson 3 point draft control system. Whatever source gave you that idea was all wet!!!!
