Oil bath air fileter media
NWMO 901 SOS
01-12-2008 13:47:34
Hello all,
I'm wanting to change the media in my oil bath air filter. Has anyone used this product and does anyone know if one bag is enough?
third party image
Link
TIA
Chris
NWMO 901 SOS
01-13-2008 17:57:52
 Re: Biggest thing on carb rebuild in reply to paul, 01-12-2008 13:47:34
Larry NCKS said: (quoted from post at 18:48:47 01/13/08)
Get it good and clean! I like to soak 'em in carb cleaner overnight, then wash and blow dry. Other than that, on that carb, get your float set correctly. Get an initial jet set and fine tune it from there.
I'll be sure to post my results. Waiting on parts and the time to get it back together.
Chris
Larry NCKS
01-13-2008 15:48:47
 Biggest thing on carb rebuild in reply to Ed in Northern VA, 01-12-2008 13:47:34
NWMO 901 SOS
01-13-2008 07:19:32
 Re: Oil bath air fileter media in reply to JoeyR, 01-12-2008 13:47:34
Larry NCKS said: (quoted from post at 08:41:34 01/13/08)
Hey Chris,
I'm still guessing you've got coil problems. The spark should jump an inch gap easily enough. If you put gasoline in the cylinders and she didn't fire, you've got an ignition problem somewhere!
Thanks Larry,
I don't think the ignition side had changed and the tractor went from running fine, to not hitting a lick, but it may have been on the verge of failing all along. Knowing I am looking for a full inch, I will go ahead and change points and condensor. Last pieces of iginition system to replace, plugs, wire, coil done last fall. While it apparently is not the strongest of spark, the was a clear, obvious spark on the plug when I had it pulled. Seemed like it should have been plenty to fire a splash of gas. The air cleaner needed rebuilding anyhow, dead mouse, mud dobbers, etc. and the carb will complete the basic rehab. I know it was a long post, but do you have any input on the carb rebuild. It's already apart and I will get a kit this week.
Chris
Larry NCKS
01-13-2008 05:41:34
 Re: Oil bath air fileter media in reply to Mike Gibson, 01-12-2008 13:47:34
Hey Chris,
NWMO 901 SOS
01-12-2008 20:32:01
 Re: Oil bath air fileter media in reply to djw, 01-12-2008 13:47:34
GlenIdaho said: (quoted from post at 22:54:31 01/12/08) I should have looked at the site you listed. Two bags are needed.
Thanks Glen,
I assume you are basing the two bags on the height? I didn't know if this would be preformed for the cleaner or just be a mass of steel fiber? I am getting a carb kit for the TSX-769 as well. I've read the recent posts on clean, clean, clean, don't use anytihng metal in passages. Tractor bible recommends fishing line. Should I just change the jets, needles, etc. or inspect the old ones first.
I ran the tractor for about half an hour Friday, started missing. Put old coil on and thought it ran better, but in short order it died. I thought it might have something to do with driving over a pile of dirt I was dragging into the pasture, pretty steep and pulling wheelies a bit. Last time it died it was on flat ground and would not start. Checked spark at coil, looked ok/marginal (jumping 3/16" gap), checked spark at plug, looked ok. Pulled air cleaner bowl and cleaned. Pulled air pipe off cleaner so it bypassed the cleaner all together. Still nothing. Had good flow to carb as I checked by pulling carb drain, and when I choked it I got fuel out the air side of the carb. Still nothing. I was jumping off a 12V battery so I was getting plenty of spin. Pulled plugs and put a little gas in each cylinder. Still didn't fire, but with good spark I got frusturated and pulled the air cleaner and carb. Took both apart and am cleaning/rebuilding to put back on.
I know timing is the only other thing to worry about and given the off and on nature of the problem, didn't figure I had jumped a tooth.
Sorry for the long post. The old fiber I removed was from my first effort some 17 years ago. Used fabric from furnace filter. Didn't remember where I got that idea, but when I called the local New Holland dealer, they said it was what they recommended because they couldn't find a supplier for the other. Probably used it last time on their advice. I've got a manual and have read and better understand the carb, initial settings, etc.
I know tired engine, lack of compression can act this way as well. I am sure this is no substitue for checking compression, but it seemed to pull a pretty good vacuum when I put my hand over the air intake.
Thanks,
Chris
GlenIdaho
01-13-2008 13:40:59
 Re: Oil bath air fileter media in reply to NWMO 901 SOS, 01-12-2008 20:32:01
Hi Chris;
Regarding the mesh for your air cleaner, you are correct I was going by the description given by this site. You're also right on when it comes to cleaning the carb. Can't do enough. When dirt get's into the jets they just won't run like they should. Concerning parts inspection, since you've already bought the kit, I would replace whatever comes in the kit, that way you know all is in good shape. When replacing them however make a comparison with the old ones just to make sure you have the correct parts. Sometimes things get packaged incorrectly. Also inspect those parts not replaced. I try to be a meticulous as possible when doing a carb.
I'd like to here what you find and do concerning the spark issue. Tracking down the cause can be tedious. Have fun with you tractor.
GlenIdaho
01-12-2008 19:54:31
 Re: Oil bath air fileter media in reply to NWMO 901 SOS, 01-12-2008 13:47:34
GlenIdaho
01-12-2008 19:51:59
I have not used that particular product but it looks like the media in my air gleaner. Don't know how much is in a bag, but my air cleaner had two sections. From a photo in the shop manual is appears that it holds two sections. If you need a photo let me know.
Air Force One
01-13-2008 05:34:49
 Re: Oil bath air fileter media in reply to GlenIdaho, 01-12-2008 19:51:59
Glen...please send me some encouraging pictures of your project when you get a chance! Twin to what I have. Once I hang up the AF bit, its my next project...thanks!
