Order Ford 600 Parts Online
ford 6600
acdave
01-16-2008 18:42:45
just wondered if they wee the same tractors as the late 5000 tractors i have a 7000 and love it so i was thinking about buying a 6600
sotxbill
01-17-2008 17:15:33
 Re: ford 6600 in reply to acdave, 01-16-2008 18:42:45
good points..... ..... ..... slightly more hp.. higher hydraulic flow rate, higher lift capcity, higher pwr stg pressure, smaller steering wheel, different injector nozzles,
bad points,,, wore out the hydraulic pumps a bit faster, may have had more cavitation problems..
overall better than a 5000..but may wear out a bit sooner. Look after oil and coolant changes... add ford coolant condition to coat the block for cavitation protection.(6 ounces every 2 years will do fine) expect to change hydraulic pump earlier.
RodInNS
01-16-2008 18:55:05
The 6600 has a somewhat improved hydraulic system over the 5000, along with an improved electrical system and a good iso-mounted cab if it has a Q-Cab. Otherwise they are very similar tractors. The other changes would be minor and a late 5000 is just slightly less power than an early 6600 (68 vs 70)...
Rod
