Order Ford 3000 Parts Online
3000 power steering cylinders
chuck
12-19-2001 01:59:03
I need to remove the power steering cylinder arms on a 3000 to get water out. The I&T manual says to remove the nut and "bump" them out. Has anybody done that? Thanks
TimK
12-19-2001 06:29:32
 Re: 3000 power steering cylinders in reply to chuck, 12-19-2001 01:59:03
Yep. Did the job about 3 weeks ago. You probably will need a tie rod removal tool, which is in essence a slotted wedged shaped pry bar which you can force between the parts and then hit with a hammer. But I don't think you have to remove both ends of the cylinder. If you remove just the front part from the steering rod and then remove the fluid lines on the back, you should be able to pump the cylinder rod manually and pump out most of the excess oil out of the cylinder. My $.02
