Order Ford 801 Parts Online
801 front axle eye bolts
Allen Hunt (Edw
01-20-2008 16:46:37
I read somewhere that forged-steel shoulder eye bolts on the front axles are good for rigging the tractor on a trailer.
Any one know the correct size and who would supply these? Are the axle adjustment holes threaded? What gauge thread?
Thanks,
Allen
Allen Hunt (Edwardsville,
01-22-2008 07:27:08
 Re: 801 front axle eye bolts in reply to Allen Hunt (Edwardsville,, 01-20-2008 16:46:37
Thanks for the replies. I check on the shackles.
Allen
soundguy
01-21-2008 06:54:11
I like the shackle idea, or the eye bols.. heck.. even captive hooks would be good ideas!
soundguy
Old Ford Mechanic
01-20-2008 23:15:17
Allen,The holes are non-threaded 5/8".Here is a suggestion however.On the bottom of the front axle support you will find two holes also.I use a shackle on each side mounted to these holes.I then use my chain through these shackles.This keeps the chain down under the axle itself and off the paint.Also an eyebolt is reccomended for a straightline pull,but not from the side.They lose a lot of strenght when rigged that way.I don't remember what size shackles i use but the pin just will go through the hole.I can look tomorrow and post it for you.
awhtx
01-20-2008 18:00:58
The holes in the axles are not threaded. I don't recall the size of the holes but they are rather large- maybe 5/8". You should be able to find eye bolts at a bolt & nut supply house. I'd just wrap the chain around the axle.
