Order Ford 801 Parts Online
1960 Ford 801Select -O-Speed transmission
Mark Williams
12-19-2001 05:56:28
I am considering purchasing a used Ford 801 tractor with attachemnts. I have read some negative comments concerning the Select-O-Speed transmission system. Does anyone out there have any information I can used to make a good decision ?
The Ford 801 is a 4WD version of the 800, Any information concerning the tractor and what to look for would be graciously accepted.
Thanks Mark
Larry NCKS
12-23-2001 06:31:45
 Re: 1960 Ford 801Select -O-Speed transmission in reply to Mark Williams, 12-19-2001 05:56:28
IF it has been updated to the "blue" transmission it's likely to be more reliable than the original "red" tranny that had the overunning clutch. Reds would freewheel in 5, 6 and 9 because of this feature. Blues replaced the overunning clutch with a direct drvie clutch and had no freewheeling gears. the outer appearance is slightly different on the inching pedal and top cover. They may be painted red to match the tractor. My grandpa had one he updated and had them paint it to match the tractor.
Ron Mc MO
12-20-2001 16:44:18
Mark, You have every reason to be skeptical of a SOS. If you're not familiar with the system, be careful. You might also want to read in the archives concerning SOS. We have 1 now that is worth about $1500 if it was not SOS it would be worth about $3500. Good luck, Ron
Tony Jacobs
12-19-2001 20:46:30
Hi Mark, What Info. do you want ? , I have both Gas and Diesel S.O.S. Tractors all Four Wheel Drive and would not trade them for any other tractor on the market . Where are you located ? I live in Mass. , I had sold one of my 4x4 tractors that was a 1960 871 S.O.S 4X4 without a loader to a man in Conn. Thanks Tony Jacobs
4x4 Ford - attn: Tony Jacobs
12-19-2001 14:39:30
Jeff
12-19-2001 11:06:02
I bought a '64 w/ SOS this spring (first tractor). It works fine. I would run it through all the gears. It should snap right into each gear. You can check for slipping by braking and seeing if the engine starts to load down.
