Ford 641 hydraulic lifting capacity?
AlbertA in PA
01-25-2008 19:04:27
Can anyone tell me how much weight can be picked up with the 3 point hitch system on a Ford 641 tractor? I want to buy the heaviest disk I can lift with the 3 point.
phil(va)
01-27-2008 05:18:31
 Re: Ford 641 hydraulic lifting capacity? in reply to AlbertA in PA, 01-25-2008 19:04:27
Old is correct that the lift will pick up more than the front end will allow. Keep in mind, if you ever want to load this tractor on a trailer with the disk attached that it can get real dicey when you are going up a trailer ramp with the weight on the back and the front comes up and you suddenly lose steering half way up the ramp.
old
01-25-2008 20:46:37
A lot depends on how much weight you have up front. It should/will have enough lift to stand it up on its butt. So as far as safely around 900lbs if even that much depending on a lot of other things
