Re: Another one arm loader on Ebay.
rjacksonky
01-26-2008 16:26:11
Thanks for asking.
I now have 2 one arm loaders. I bought one thinking it would fit my 801. But it is for a 1000 series ford, like a 3000 or 4000. I am going to sell it some time, I have most the brackets for it. I finally found a one arm for my 801 with all the brackets. Now I need a valve to go on the tractor to run it. I guess I will chain down my 3 pt. hitch arms til I find a valve.
garymm
01-26-2008 17:15:55
 Re: Another one arm loader on Ebay. in reply to rjacksonky, 01-26-2008 16:26:11
You are in luck, I have a original FORD hydraulic control for your 801 for $375.00 GOOD in IOWA
rjacksonky
01-27-2008 05:45:50
 Re: Another one arm loader on Ebay. in reply to garymm, 01-26-2008 17:15:55
Too high for me. I am a poor Ky boy. I can't justify paying that much for a valve when the loader cost me a lot less than that.
I should have bought the one on Ebay like the one you have for $200 the other day. Thanks,
John O (MI)
01-28-2008 09:07:38
 Re: Another one arm loader on Ebay. in reply to rjacksonky, 01-27-2008 05:45:50
For valves, I've got one like ebay item # 160202973020. It has one single acting, and one dual acting spool - perfect for the hydraulic one-arm loader. This valve is not as desirable as the one with the levers out the side, as this one cannot be switched to work with two dual acting cylinders. But other than that, it gets the job done.
No vested interest here. Just saw the listing on ebay.
-John
awhtx
01-28-2008 14:07:31
 Attn: John O (MI)- Remote Valve information in reply to John O (MI), 01-28-2008 09:07:38
I have a valve that looks similar to the one on ebay. Mine has 2 hoses attached to the top spool just like the one in the photo. My lower spool has 2 ports on opposite sides of the housing and only one of them has a hose- the other is plugged. Is my valve a DA/SA or is it DA/DA?
John O (MI)
01-28-2008 16:49:52
 Re: Attn: John O (MI)- Remote Valve information in reply to awhtx, 01-28-2008 14:07:31
If you've got 4 hose ports, it should be two DA spools. Very interesting. I haven't seen one in this style that is configured for two DA. Mine and others that I have seen have two hose ports on the left side, but only one on the right.
Also, if one of the ports is plugged, there should be some sort of selector to switch that spool from DA to SA. Otherwise, you would pop the relief valve while lowering the SA cylinder. I recall a post by Soundguy describing how the selector works on his Tisco valve. Yours would need to have something similar.
-John
