Order Ford 2000 Parts Online
ford 2000 autolite distributor , need parts
532dawes
01-27-2008 11:47:06
The vacuume advance dosen't work on my Autolite distributor. The tractor is a 67 Ford 3 cyl gas. Does anybody know if this part is available?
Thanks
532dawes
01-28-2008 09:01:33
 Re: ford 2000 autolite distributor , need parts in reply to 532dawes, 01-27-2008 11:47:06
Tom- Wisconsin Tractor had the part in stock, just ordered it. NH didn't stock the part, but had a distributor for $400!
Thanks for that contact!!!
John- Thanks for the "secrets" that helped.
532dawes
01-28-2008 07:59:05
John- thanks for the "secrets"
Bob- like you said not stocked any more. will check the contacts you mentioned.
532dawes
01-28-2008 07:39:16
John- Thanks for letting me in on the "secrets" Bob- thanks for the tip on where to get the parts.
Tom in TN
01-27-2008 16:32:32
Dawes,
I have a 1973 Ford 2000 3 cylinder gas that had a bad vacuum advance diaphram. My local NH dealer said that it was no longer available. I eventually contacted All-States Ag Parts at asapagparts dot com. They apparently have a network of parts places that work together. They referred me to Wisconsin Tractor in Black Creek, WI at 877-530-2010. Mike Like at Wisconsin Tractor was very helpful. I had the part within a couple of days and installed it the day it arrived.
I don't remember the exact cost, but it was very reasonable.
Good luck finding one.
Tom in TN
Bob
01-27-2008 13:14:27
Third Party Image
3-Cylinder? And, does #34 look like what you need?
C5NF12370A DIAPHRAGM Distributor Diaphragm Assy., Includes: Housing, Diaphragm, Couplers & Ref. 35, Start Year: 01/01/1965
Check with your NH dealer in the morning. I'll also check, and post what I find.
532dawes
01-27-2008 14:08:12
 Re: ford 2000 autolite distributor , need parts in reply to Bob, 01-27-2008 13:14:27
Yes that's it, thanks- will check with NH.
john in la
01-27-2008 16:59:25
 Re: ford 2000 autolite distributor , need parts in reply to 532dawes, 01-27-2008 14:08:12
third party image
N.H. still shows it as a good part #.
Tom in TN
01-28-2008 03:34:52
 Re: ford 2000 autolite distributor , need parts in reply to john in la, 01-27-2008 16:59:25
John in LA,
That is way cool! How do you actually access NH's parts availability like that? I have a parts manual, so I can find parts without much problem, but I don't know how to access NH's availability. I trust my local dealer, but I'd like to be able to check on availabilty during off-hours.
Any help would be greatly appreciated.
Tom in TN
532dawes
01-27-2008 17:44:51
How do you guys find the parts #'s ?
john in la
01-27-2008 18:13:19
 Re: ford 2000 autolite distributor , need parts in reply to 532dawes, 01-27-2008 17:44:51
Now if we told you all our secrets
then it would not be a secret anymore.
Right????? ????
LOL..... ...
Follow the link
Put your model # (2000) in the search
box and then just follow the links.
