Order Ford 2000 Parts Online
1966 ford 2000
bigcow1
01-28-2008 13:32:12
hi guys to get tractor to run right you have to pull choke ouy all the way it is 3 cyl gas i ck float needle after it warms up it is better you can push choke back in till you try to take off then you need to pull choke back out i took fuel line apart i think fuel pump is ok i could sure usesome help THANK YOU MUCH JERRY
3000OH
01-28-2008 17:32:16
 Re: 1966 ford 2000 in reply to bigcow1, 01-28-2008 13:32:12
Betcha have a Holley carb on it. Common problem, usually focused on the accel pump. Search the archives here for Holley or Holly and you can read up on it. Same carb was used for "65 and later 2000/3000/4000 models. 50% manage to get "em fixed, the other half don"t, the latter look at Zenith replacements. Been there, done that, we love our Zenith.
bigcow1
01-29-2008 12:40:59
 Re: 1966 ford 2000 in reply to 3000OH, 01-28-2008 17:32:16
THANKS GUYS MUCH JERRY
soundguy
01-28-2008 13:41:00
Needs choke to run:
fuel obstruction
weak sparks
vacume leak.
take yer pic...
soundguy
