Attn: John O (MI)- Remote Valve information
awhtx
01-28-2008 14:07:31
I have a valve that looks similar to the one on ebay. Mine has 2 hoses attached to the top spool just like the one in the photo. My lower spool has 2 ports on opposite sides of the housing and only one of them has a hose- the other is plugged. Is my valve a DA/SA or is it DA/DA?
John O (MI)
01-28-2008 16:49:52
 Re: Attn: John O (MI)- Remote Valve information in reply to awhtx, 01-28-2008 14:07:31
If you've got 4 hose ports, it should be two DA spools. Very interesting. I haven't seen one in this style that is configured for two DA. Mine and others that I have seen have two hose ports on the left side, but only one on the right.
Also, if one of the ports is plugged, there should be some sort of selector to switch that spool from DA to SA. Otherwise, you would pop the relief valve while lowering the SA cylinder. I recall a post by Soundguy describing how the selector works on his Tisco valve. Yours would need to have something similar.
-John
