Ford 1720 Hydraulic Pump removal
Bob Rutherford
01-28-2008 20:55:36
Ford 1720 (1988 compact model, manual gearbox, 2WD, factory loader) overflowed the crankcase with hydraulic fluid. The Service mgr. at F/NH dealer recommended new pump. Turned out replacement pump model was changed over, also requiring new suction and hi press.pipes (rigid). New pump looks much like the power steering pump, much smaller than the original oval hydr. system pump. I was able to get a seal kit for the original pump, which looks fine inside, but here's my specific problem: The orig. oval hydr. pump mounts (with six bolts) to an adapter base on the rear side of the drive housing. This adapter base, which contains the oil seal that I think has failed, has four studs extending thru the drive housing, the nuts of which secure the power steering pump on the front side. I cannot access the two nuts in next to the engine block, preventing me from removing the adapter base. This must be removed to either a/ replace the seal to re-use the original rebuilt pump, or b/ the changed-over replacement pump has a short drive with a four -bolt flange and mounts directly to the drive housing, not utilizing the original adapter base. Either way it has to come off. Does anyone know a secret to get at the inside nuts on the power steering pump base flange? At the moment I'm stuck. I prefer to use the original set-up because I know that the rigid pipes all fit properly and the normal speed of the hydr. system will be maintained. The changed-over system, who knows how it will fit up and perform?
Would very much appreciate any suggestions! Sorry for the length of this posting, but I hope the problem is clearly described.
soundguy
01-29-2008 11:07:41
 Re: Ford 1720 Hydraulic Pump removal in reply to Bob Rutherford, 01-28-2008 20:55:36
Whichever way you go.. DO check one thing.
if the shaft seal blew out ont he pump allowing hyd fluid into the crank case.. find out what happened to cause it.
Was a relief valve stuck? did a hyd quik connect become half way unplugged. I've seen that alot on smaller chinese tractors that have qd's in line with the hyd pump.. the qd partially splits, and then the shaft seal blows.
Do get that crankcase oil changed too!
soundguy
Bob Rutherford
01-29-2008 17:36:40
 Re: Ford 1720 Hydraulic Pump removal in reply to soundguy, 01-29-2008 11:07:41
Thanks for the feedback, Soundguy. You are absolutely correct about the relief valve comment. The externally actuated relief valve linkage on the rear RH lift arm is broken because that valve actuator shaft is seized tight and I've been unable to get it freed up (???) Normally I compensate for that by dropping the 3PH control lever a bit until the hitch still stays up, but the excess pressure is relieved. You can hear this by a slight variation in engine speed. (I know, Mickey Mouse - I should have got that fixed properly) Of course, someone other than myself used the tractor for several hours plus an hour running the road and was unaware of this - i figured that led up to the problem. I'm working on that relief valve too with no success to date, and yes, an oil change will be done immediately once I get it back together again. Meanwhile I,m still held up by the two inside nuts on the power steering pump base flange. May have to remove front bodywork and rad to gey at them. yuck. I used to like this little tractor.....Thanx again - Bob.
soundguy
01-30-2008 06:26:11
 Re: Ford 1720 Hydraulic Pump removal in reply to Bob Rutherford, 01-29-2008 17:36:40
Good luck on that.
Yep.. front tin may be stopping you.
DO get the linkage in the rear attended to to get those hyds shut off.. etc..
soundguy
