NWMO 901 SOS
02-04-2008 17:54:01
Re: 901 Oil Pressure guage in reply to Texasmark, 02-02-2008 21:28:42
Bob said: (quoted from post at 23:15:34 02/03/08) You need (I think) some 1/8" line, with a "compression nut" to match. |
Thanks Bob and everyone,
After visiting Carquest and NAPA, I was going the 1/8" copper line side with compression fitting at the guage. I am leaning towards reusing the old SAE?? fitting and flaring the copper line similar to the old steel. I know the copper is considerably softer, but if I don't get carried away, I should be ok. I didn't like the idea of splicing the line in the middle somewhere. The oil line they provide is likely thin to make it easy to shape, but when I inspected the sweat fittings on the end, the 1/16" or 3/32" copper line was virtually flattened in the brass fitting. There was less than a 1/16" for the oil. Probably would work fine, but I worried it may interefere with the guage (to much restriction). Dumb question, do I just hook the new line up and go?? I assume the oil compresses the air and that registers on the guage? I wasn't sure if you wanted oil all the way to the guage or if it worked out that way over time, the air getting pushed out. Thanks everyone. I'm still disappointed with the purchase, that tiny line and riduculous time waster of chasing a nearly impossible fitting. They shouldn't list it for the 971. Others may be able to walk right to the fitting, but the local Westlakes, Carquest, Autozone and NAPA only deal in NPT fitting, compression fittings and flare fittings. I didn't find anyone with a matching thread to the original part. Very near the 1/8" NPT, but the nut would only screw about one turn before locking up. Thanks for letting me vent. Moral of the story, you get what you pay for, if it seems to good to be true it probably is.
Chris
