Order Ford 640 Parts Online
ford 640 running weird
another ford gu
02-07-2008 18:01:44
I have a 640 ford that while working it,(pushing snow,mowing,etc) it will just die. Somedays I can run for 1hr somedays 15 min. I have noticed that it will run longer when I clean the carb and it is not completly warmed up. When it dies I can choke it and then it will start right back up. I have checked electrical. I have got a new float, needle valve and seat. any other suggestions will be appreciate
scpurgatory
02-08-2008 17:44:18
 Re: ford 640 running weird in reply to another ford guy, 02-07-2008 18:01:44
just to confirm what "old" said....buddy of mine fought and fought a balky tractor...found a dadgum cigarette butte in the gas tank...guess it block the line every now and then...who would have thunk of that one...
bustedknuckles
02-08-2008 08:51:36
When your tractor shuts down check your sediment bowl. If its empty then you know you have an obstruction. Also how old is your gas? I've had tractors shut down because of bad gas.
bustedknuckles
02-08-2008 08:51:31
soundguy
02-08-2008 08:04:55
deffinately sounds like fuel obstruction.
soundguy
john_bud
02-07-2008 18:57:53
Turn off the gas valve at the tank, remove the line from the carb and check the flow out of the tank. Run out as much as you can. If the flow fluctuates, you may have a leaf or hunk-o-junko in there. May have to completely drain the tank, remove the valve, clean the tank and valve and replace.
jb
old
02-07-2008 18:10:57
Sounds like you might have something in the gas tank that will some times clog the line and other time not clog it
scpurgatory
02-08-2008 17:38:31
 Re: ford 640 running weird in reply to old, 02-07-2008 18:10:57
