Order Ford 3000 Parts Online
3000 battery tray
hugh
12-25-2001 09:36:17
The swing out battery tray on my 3000 has been eaten through in a few pretty big places and I would like to repair it. I thought about fiberglass or bondo. It's contoured so I don't know if welding would work or not. Anybody repaired one of these before? It also looks like I should replace my wiring harness as the insulation is hard and breaking. Does anyone know of a source and about how much it would cost? Thanks in advance.
SamMI
12-25-2001 15:31:05
 Re: 3000 battery tray in reply to hugh, 12-25-2001 09:36:17
Hi Hugh; You didn't say whether gas or diesel. You can get tray at FNH. Gas tractor D3NN10723A, or diesel E4NN10723AA. HTH
JDP
12-25-2001 15:41:28
 Re: Re: 3000 battery tray in reply to SamMI, 12-25-2001 15:31:05
I'm not sure about the 3000, but I know that the 5000 gas and diesel have the same battery tray. The gas had a spacer in it to hold the 17TF battery, but I took that out and put a 4DLT in it.
jim
12-25-2001 15:22:46
Once you get a replacement , line the tray with sheet lead. I did that on my 5000's tray years ago and tray is good as new yet. Got the sheet lead from the tin-bashers on a construction site.
RickB.
12-25-2001 11:58:44
When searching boneyards for the battery tray, specify gas or diesel, they are different. I think all 3 or 4 cylinder X000, X600, X610 using the same fuel will use the same tray.
RickB.
12-25-2001 12:00:26
 Re: Re: 3000 battery tray in reply to RickB., 12-25-2001 11:58:44
Just to clarify, the above post refers to tractors built 1965 and up.
JDP
12-25-2001 10:56:44
As far as the wiring harness goes, you will probably have to go to Ford to get that. The battery tray you might be able to find at a salvage yard. Go to www.atis.net, and look under salvage yards and start calling.
