Soundguy- we need your help
awhtx
02-10-2008 07:05:57
Since you own both a 660 and a 850 can you measure the diameter of the rear axle gear housings and post that info here. Also we're trying to determine casting numbers used on the 600/800/601/801 rear axle housings. The casting number is found jus aft of the PTO engagement lever.
awhtx
02-11-2008 17:49:15
 My 861 rear axle measures about 17.5 diameter in reply to awhtx, 02-10-2008 07:05:57
That's top to bottom on the left side of the top link.
sadsack
02-12-2008 00:31:51
 Re: My 861 rear axle measures about 17.5 diameter in reply to awhtx, 02-11-2008 17:49:15
Thanks. Mine measured the same, so that would make it an 841 with a 641 transmission. When Dad bought the tractor it had a loader on it. Either the transmission broke or they wanted the Sherman for working the loader. The code dates for the engine and rear end are close, and the serial number on the transmission dates it to Feb '59. The code date for the transmission is odd, (8BX) it doesn't match with the system. It could be a 3, but I sure it's a B. There is no doubt about the X though.
engine 310609 92E trans 310865 8BX rear 312480 92E
