proofmeter lubricant
NWMO 901 SOS
02-13-2008 04:49:40
Good Morning all,
Another single digit temp this morning, I'm ready for a thaw and some spring weather, shouldn't be long. My proofmeter had seized on me so I took it apart and have now cleaned up the "drive shaft" where the problem was and it spins nicely. I am left with roughly 1/32" to 3/64" difference from the drive radius to the "carrier" radius. Any opinions on what to lubricate with. It appears to have had some type of grease or oil originally, but I didn't know if I may be better off w/ graphite after my work. Graphite, lithium, 3 n 1, or a more typical grease?. Shouldn't be much dust get to it after it's together, but there is always that chance. All opinions appreciated.
Chris
kcred
02-13-2008 09:17:32
 Re: proofmeter lubricant in reply to NWMO 901 SOS, 02-13-2008 04:49:40
What ever you use, clean the old lubricant off , thoroujhly. Sometimes when old grease is mixed with new grease, it will harden up and not lub .
Red
sotxbill
02-13-2008 06:49:29
I have used modern grease, white lube, and wd40..
remember that graphite and water dont mix. graphite based products will cause servere coorosion on any adjacent metal products.
older grease products were waxed based and would eventually harden up.. modern grease products will not wax up but will change in vicosity as the temperature drops, but not nearly as bad as the older parafin based products. The new products are made to be pliable in sub zero temps.
so just pick a modern synthetic grease product and go crazy...
NWMO 901 SOS
02-13-2008 06:38:56
 Re: proofmeter lubricant in reply to old, 02-13-2008 04:49:40
Michaels Dad said: (quoted from post at 09:20:20 02/13/08) Mine worked smoother after cleaning off the grease, and going to powdered graphite.
Thanks Guys,
I hope to get it back together and on the tractor this weekend. I will let you know how it goes. Thanks again.
Chris
36 coupe
02-13-2008 13:37:25
 Re: proofmeter lubricant in reply to NWMO 901 SOS, 02-13-2008 06:38:56
Find some LSA military gun oil. its sticky so it stays put on moving parts.Dont use wd 40 it leaves a gummy residue behind when it evaporates.
Michaels Dad
02-13-2008 06:20:20
 Re: proofmeter lubricant in reply to Dan (nyc), 02-13-2008 04:49:40
Jerry Cent Mi.
02-13-2008 05:24:52
I must have broken my cable yesterday. It was very cold and when the tractor started the meter started to go nuts.
souNdguy
02-13-2008 05:16:09
Graphite or key/lock lube would be my 1st guess..
soundguy
